HP Anyware Administrators' Guide
Prerequisites for Zoom VDI for HP Anyware
This section lists the prerequisites for installing and using Zoom VDI for HP Anyware.
OS Requirements
  • On agent machines, any Windows Server version mentioned in the "System Requirements" topic in the Windows agent guides must be installed.
  • On client machines, any Ubuntu version mentioned in the "System Requirements" topic in the Linux client guides must be installed.
HP Anyware Requirements
  • Graphics Agent for Windows 25.03 or later
  • Standard Agent for Windows 25.03 or later
  • Software Client for Linux 25.03 or later
Info
At present, Zoom VDI is only supported while connecting to Anyware Windows Agent machines.
Zoom VDI Requirements
  • Zoom VDI Client Host version 6.2.10
  • Zoom Media Plugin version 6.2.12 or newer
Installation Workflow
Step Description
I Install or upgrade Anyware Agent for Windows to version 25.03 or later.
II Install or upgrade Software Client for Linux to version 25.03 or later. For more information, see the "Installing" topic in the client guide.
III For fresh installation, install the Zoom Media Plugin on thin clients first.
For upgrades, update the Zoom VDI Client Host first.
IV Install either the Zoom Media Plugin or the Zoom VDI Client Host, which will depend on whether you're performing a new installation or an upgrade.
Last updated: Wednesday, February 26, 2025
