25.10.0 Administrators' Guide
Anyware Remote Workstation Card Agent for Windows Installation Guide
Before you proceed with installation, a few prerequisites must be met.
Prerequisites
These instructions assume you have already built the remote desktop machine, and that the machine meets the agent's requirements.
A few other things to confirm before proceeding:
  • You should have already installed the Remote Workstation Card Software for Windows on the desktop machine.
  • The desktop machine requires the following ports to be open: TCP 443, TCP 60443, TCP 4172, and UDP 4172.
  • You should be able to run applications as an administrator.
  • The Remote Workstation Card Agent for Windows must be able to execute PowerShell scripts. If your PowerShell execution policy set to Restricted, the execution policy will be automatically changed so installation can proceed. If the agent cannot execute PowerShell scripts or change the execution policy, the installation will fail.
  • If you are using a Local License Server, you'll need to know it's URL and port numbers.
Installation Overview
Once your prerequisites are in place, you can proceed with installation. Here's a brief overview of the process:
  1. Temporarily connect a physical display, mouse, and keyboard to the machine for installation.
  2. Download or transfer the Anyware Remote Workstation Card Agent for Windows installer to the system.
  3. Install the Anyware Agent using one of these methods:
    • Using the installer's setup wizard for a guided, interface-driven process, or
    • Silently using a script
  4. If required, configure the agent software.
  5. Disconnect physical display, mouse, and keyboard.
  6. Connect to the desktop using a Anyware client.
If you're ready to start, proceed to installation.
Last updated: Thursday, July 17, 2025
