Changing the Language¶
In addition to English, the PCoIP Software Client also supports a number of different languages. During installation, you can select one of the supported languages.
To change the language in GNOME
- In the Settings > Language and Region panel, select another language from the language setting.
To change the language on the command line
Alternatively, the language can be set with the locale
parameter on the command line:
pcoip-client --locale <locale-code>
The following table lists the available language translations and codes:
Language | Code |
German | de |
Spanish | es |
French | fr |
Italian | it |
Japanese | ja |
Korean | ko |
Portuguese (EU) | pt |
Portuguese (Brazil) | pt_BR |
Russian | ru |
Turkish | tr |
Chinese (Simplified) | zh_CN |
Chinese (Traditional) | zh_TW |
