Detect Monitors
The detect monitors feature enables you to add and remove displays from the desktop through the PCoIP Client while in an active session.
Adding a Display
The following steps outline how to add a display to your desktop through the PCoIP Client:
- Connect a new monitor to the client.
- From the desktop, click View.
- Click Detect Monitors.
- Select the monitor you want to add.
The displays on the remote desktop will be extended to include the new monitor.
Removing a Display
The following steps outline how to remove a display from your desktop.
- Disconnect a monitor from the client.
You will no longer see the monitor that you have disconnected from the client.
