Reset Virtual Desktop
The following section outlines how to reset a saved desktop in the PCoIP Client. You can reset to a virtual desktop by following the steps outlined below:
- Click the configure button and select Edit from the popup menu.
- Click NEXT on the initial saved connection screen.
- Enter your access credentials and click SAVE.
- Click the configure button and select Reset. If the Reset option is not available, then this feature is not supported by the Connection Manager.
