Skip to content
Using Displays
When you connect to a PCoIP session, the Anyware Client for Linux shows your remote desktop as one or more displays. The number of displays it shows is constrained by your local system's available monitors (and the PCoIP protocol itself, which supports up to four monitors).
You can choose whether the Anyware Client for Linux shows your remote session as a single display in a resizable window, or as one or many full-screen displays.
You can also add or remove local displays during a session.
Display Modes
Using the Anyware Client for Linux, you can switch between three display modes. Note that some of these modes are system-dependent; for example, if your local system has only one monitor, you will not see options for multiple displays.
Windowed Mode
In Windowed mode, the Anyware Client for Linux provides a single window, resizable and movable, which contains the remote desktop. The remote desktop will rescale to fit your window dimensions if you change them.
To use windowed mode:
  1. Reveal the Anyware Client for Linux menu bar by moving the mouse cursor to the top of a display.
  2. From the Anyware Client for Linux menu bar, select View > Leave Fullscreen.
Full Screen Modes
In full-screen modes, the Anyware Client for Linux expands to fill either one local display or all of your local displays.
In both full-screen modes, the Anyware Client for Linux menu bar is hidden. To reveal it, move your mouse cursor to the top of the display and hover for a moment.
Tip: Quickly switch to full-screen mode
You can quickly switch from windowed mode to whichever full-screen mode you used last by pressing ctrl+alt+Enter.
Full Screen All Monitors
In full screen all monitors mode, the application expands to present full-screen remote displays on all of your local monitors. The remote desktop will map a remote display to each of your local displays.
You will only see this option if your local system has multiple displays.
To use Full Screen All Monitors mode:
  1. If you are in full-screen one monitor mode, reveal the Anyware Client for Linux menu bar by moving the mouse cursor to the top of a display.
  2. From the Anyware Client for Linux menu bar, select View > Fullscreen All Monitors.
Full Screen One Monitor
In full screen one monitor mode, the presents a single full-screen remote display on one of your monitors.
If you switch from Full Screen All Monitors to Full Screen One Monitor, all open windows and applications will be moved onto the single display.
Tip: Monitor selection
The local monitor chosen for full-screen display depends on the mode you are switching from:
  • If switching from windowed mode, the client's current display becomes full-screen.
  • If switching from full screen all monitors mode, the display used to select fullscreen one monitor mode becomes full-screen.
To use Full Screen One Monitor mode:
  1. If you are in a full-screen mode already, reveal the Anyware Client for Linux menu bar by moving the mouse cursor to the top of a display.
  2. From the Anyware Client for Linux menu bar, select View > Fullscreen One Monitor.
    Note: Systems with only one display
    If your local machine has only one display, the menu option will say Show Fullscreen.
Adding or Removing Displays
You can add or remove local displays during a PCoIP session. If you are using full screen all monitors mode, you must detect the changes before they will be effective. Note that in the case of removing monitors, this could mean that some applications or information is inaccessible until the detect monitors command is issued.
Detecting Monitors
If the local display configuration changes during a session—for example, if you attach a new local monitor, or disconnect an old one—the display mapping between the local and remote topographies is no longer accurate,leading to unpredictable display behavior. You must be refresh the display mapping to accurately show the new configuration.
To synchronize local display changes:
  2. From the Anyware Client for Linux menu bar, select View > Detect Monitors.
The local display configuration will synchronized with the remote. The local displays may flicker or go black momentarily while the remote system updates its display topography.
