Prerequisites for Zoom VDI for HP Anyware¶
This section lists the prerequisites for installing and using Zoom VDI for HP Anyware.
OS Requirements¶
- On agent machines, any Windows Server version mentioned in the "System Requirements" topic in the Windows agent guides must be installed.
- On client machines, any Ubuntu version mentioned in the "System Requirements" topic in the Linux client guides must be installed.
HP Anyware Requirements¶
- Graphics Agent for Windows 25.03 or later
- Standard Agent for Windows 25.03 or later
- Software Client for Linux 25.03 or later
Info
At present, Zoom VDI is only supported while connecting to Anyware Windows Agent machines.
Zoom VDI Requirements¶
- Zoom VDI Client Host version 6.2.10
- Zoom Media Plugin version 6.2.10
Installation Workflow¶
Step | Description |
I | Install or upgrade Anyware Agent for Windows to version 25.03 or later. |
II | Install or upgrade Software Client for Linux to version 25.03 or later. For more information, see the "Installing" topic in the client guide. |
III | For fresh installation, install the Zoom Media Plugin on thin clients first. For upgrades, update the Zoom VDI Client Host first. |
IV | Install either the Zoom Media Plugin or the Zoom VDI Client Host, which will depend on whether you're performing a new installation or an upgrade. |
