Renaming Endpoints¶
You can rename an endpoint either from its ENDPOINT DETAILS page or the ENDPOINT page.
To rename endpoints:
From the PCoIP Management Console’s top menu, click ENDPOINTS.
In either the GROUPED or UNGROUPED table, select the endpoint that you wish to rename.
Click STRUCTURE and then RENAME.
Enter a unique name for the endpoint (from within its group hierarchy) and click RENAME ENDPOINT.
Note: Auto naming endpoints
If you have configured a global naming convention for endpoints that applies when they move to or from a group, this overrides any manually configured endpoint name. If you then move the endpoint into or out of a group, the automatic naming rule will apply. See Auto Naming Endpoints.
