Troubleshooting DNS¶
This troubleshooting reference provides some steps to perform to ensure that you have the correct PCoIP Management Console information configured in your DNS server.
Note: Instructions are for Windows only
These instructions apply to the Windows platform.
The procedure shown next checks that you have a DNS A record that maps the PCoIP Management Console’s host name to its IP address for forward lookups, and a DNS PTR record that maps the PCoIP Management Console’s IP address to its host name for reverse lookups. In addition, it checks that a DNS SRV record for _pcoip-bootstrap exists, and that the DNS TXT record containing the PCoIP Management Console’s certificate fingerprint exists and is located in the right place.
Also note that:
DNS records have a time-to-live value that dictates how long the records are cached. If your nslookup results show old information, please try clearing the PC’s DNS cache using the
ipconfig /flushdns
command before running the nslookup commands in this example again.
For example,
C:\Users\username> ipconfig /flushdnsWindows IP Configuration Successfully flushed the DNS Resolver Cache
PCoIP Zero Client endpoints will cache DNS results for the entire time-to-live period. You can clear this cache by power cycling the endpoint.
The following SHA-256 fingerprint shown is the default PCoIP Management Console certificate fingerprint. If you have created your own certificates, this value will be different.
The following example uses sample IP addresses and host names for the primary DNS server and PCoIP Management Console. Please substitute your own server and PCoIP Management Console 2 information for these names and addresses.
The information returned by the nslookup commands is shown in gray text after each command.
To verify DNS PCoIP Management Console information:
Log in to your Windows server.
Launch a command prompt window by clicking the Start button and typing cmd in the Search box.
Launch nslookup from the command line prompt:
C:\Users\username> nslookup
Default Server: mydnsserver.mydomain.local
Address: 172.15.25.10 -
Instruct nslookup to connect to the DNS server under which you created the records. This address should match the primary DNS server address configured in the endpoint’s network settings.
> server 172.15.25.10Default Server: mydnsserver.mydomain.local
Enter the FQDN of your PCoIP Management Console to perform a forward lookup to verify that a DNS A record that maps the PCoIP Management Console host name to its IP address is present:
> pcoip-mc.mydomain.localServer: mydnsserver.mydomain.local
Address: 172.15.25.10Name: pcoip-mc.mydomain.local
Address: 172.25.15.20 -
Enter the PCoIP Management Console’s IP address (found in the previous step) to perform a reverse lookup to verify that a DNS PTR record that maps the PCoIP Management Console IP address to its host name is present:
> 172.25.15.20Server: mydnsserver.mydomain.local
Set the record type to SRV and check that a DNS SRV record exists to tell endpoints the FQDN of the PCoIP Management Console. In the second command, the domain name is the domain under which your endpoints are configured:
> set type=srv
> _pcoip-bootstrap._tcp.myendpointdomain.localServer: mydnsserver.mydomain.local
Address: 172.15.25.10:> _pcoip-bootstrap._tcp.myendpointdomain.local SRV service location:
priority =0
weight =0
port =5172
svr hostname =pcoip-mc.mydomain.local
pcoip-mc.mydomain.local internet address = 172.25.15.20 -
Set the record type to TXT and check that a DNS TXT record exists containing the PCoIP Management Console SHA-256 fingerprint. In the second command, the domain name is the domain under which your endpoints are configured.
> set type=txt
> pcoip-mc.myendpointdomain.localServer: mydnsserver.mydomain.local
Address: 172.15.25.10pcoip-mc.mydomain.local text = "pcoip-bootstrap-cert= B7:62:71:01:85:27:46:BB:E3:E9:5C:E2:34:2C:B5:76:7D:7A:F1:7F:6A:4D:5C:DB:AA:2B:99:BD:D5:A9:28:91"
Exit nslookup:
> exit
