Displaying Endpoint Properties¶
The ENDPOINTS page, displayed next, contains GROUPED and UNGROUPED tables for displaying the endpoints in your system that are managed by the PCoIP Management Console.
View of the ENDPOINTS page
Selecting Endpoint Properties to Display¶
Click the gear icon to the right of the table to change the information you want to display in the table columns. Your customized settings are saved in your browser and will be used for any user who subsequently logs in from that browser.
Properties are ordered in the sequence you select them. You can rearrange a column by manually dragging the column heading to the desired position. You can also sort endpoints in ascending or descending order based on column contents by clicking on the column heading. Endpoints that occur in groups are sorted within their group.
You can choose to display the following properties:
Endpoint Properties
Property | Information | Grouped | Ungrouped | MC Enterprise Only |
ATTACHED USB DEVICES | Displays information from attached USB Devices. Possible values:
:fa-check: | :fa-check: | :fa-times: |
AUTO CONFIGURATION STATUS | Displays an endpoint’s auto configuration status. Possible values:
:fa-times: | :fa-check: | :fa-times: |
APPLY PROFILE | Displays the status of endpoint’s profile update. Possible values:
Some common reasons for the 'skipped' status is if the endpoint is already configured with the profile settings or if its group does not have an assigned profile. |
:fa-check: | :fa-times: | :fa-times: |
CERTIFICATE EXPIRY DATE | Displays the date the SCEP certificate will expire and become not valid. Possible values:
CERTIFICATE NAME | Displays the SCEP certificate subject name. Possible values:
CERTIFICATE RULE | Displays the SCEP certificate rule assigned to a group. This rule defines the SCEP SERVER address and password that an Endpoint can use to request a SCEP certificate. You can create a certificate rule from the ENDPOINT CERTIFICATE tab. Possible values:
CERTIFICATE START DATE | Displays the date the SCEP certificate becomes valid. Possible values:
CERTIFICATE STATUS (PCoIP Zero Client only) |
Displays the status of the SCEP certificate. Possible values:
CLEAR MANAGEMENT STATE | Indicates if devices now have all management settings cleared and set back to a default state. | :fa-check: | :fa-times: | :fa-times: |
CONNECTED BY | Identifies where in the deployment the PCoIP endpoint is placed. Possible Values:
:fa-check: | :fa-check: | :fa-check: |
DENIED | Indicates whether or not the PCoIP Management Console has enough licenses to manage all the discovered endpoints. Possible values:
DEVICE DESCRIPTION | Displays the PCoIP Device Description text located on the endpoints AWI Label page. Possible values:
PCOIP DEVICE NAME | The MAC Address value will be set to the PCoIP Device Name field after a profile with this setting configured is successfully applied. The Device Name has a maximum length of 63 characters.
Possible values:
DEVICE STATUS | Indicates whether or not an endpoint is connected to the PCoIP Management Console and if it is in a PCoIP session with another PCoIP software or hardware endpoint. DEVICE STATUS is a combination of the previous ONLINE and IN SESSION properties. Possible values:
DISPLAY TYPE | Displays the maximum number of monitors an endpoint supports. Possible values for a PCoIP Zero Client and Remote Workstation Card:
ENDPOINT DESCRIPTION | Displays information about the endpoint family and endpoint type. | :fa-check: | :fa-check: | :fa-times: |
ENDPOINT HEALTH | Displays the status of an endpoint’s health state. Possible Values:
ENDPOINT PLATFORM | Displays the endpoint’s PCoIP family. In this release, only endpoints that support the Tera2 platform can be managed by the PCoIP Management Console. Possible values:
ENDPOINT TYPE | Displays the endpoint type. Possible values:
FIRMWARE BUILD ID | Lists the firmware build number in use on the PCoIP endpoint. Possible values:
FIRMWARE POWER RESET | Displays the status of an endpoint’s power reset after updating its firmware. Possible values:
FIRMWARE UPLOAD | Displays the status of an endpoint’s firmware upload. Possible values:
FQDN | Displays an endpoint’s fully-qualified domain name. Possible values:
GENERIC TAG | Displays the Generic Tag text located on the endpoints AWI Label page. Possible values:
GET ALL SETTINGS | Displays an endpoint’s polling status. Possible values:
IPv4 or IPv6 ADDRESS | Only the information of the network that Management Console is configured to operate in (IPv4 or IPv6) will be visible Possible values:
INTERNAL IPv4 or IPv6 | Only the information of the network that Management Console is configured to operate in (IPv4 or IPv6) will be visible. Displays an endpoint's IPv4/IPv6 address for the network the endpoint is part of. For remote endpoints, this will be their internal network addresses. Possible values:
LAST POLLED | Displays the last date and time that the PCoIP Management Console polled an endpoint for its status and configuration information. The PCoIP Management Console’s polling interval is 60 minutes. Possible values:
MAC ADDRESS | Displays an endpoint’s MAC address. Possible values:
OSD LOGO | Displays the status of an endpoint’s OSD logo bitmap file update to the endpoint’s On Screen Display (OSD). Possible values:
PEER | If a peer is configured for an endpoint, it's IP address is shown in the column. Possible values:
PROFILE | Appears next to a group to display the profile assigned to it. Possible values:
PROFILE COMPLIANCE | Indicates whether or not an endpoint’s current known configuration differs from the PCoIP Management Console profile assigned to the endpoint’s group. Possible values:
PROFILE POWER RESET | Displays an endpoint’s power reset status resulting from a profile property requiring a power reset and not a firmware change. Possible values:
RESET TO DEFAULT COLUMNS | Resets the table to display the default columns. Possible values:
SERIAL NUMBER | All endpoints provide there serial numbers to the PCoIP Management Console endpoints table. The serial number can also be exported into the Inventory Report. Possible values:
SOFTWARE VERSION | Firmware file name used in the PCoIP firmware build minus the build number. Possible values:
UNIQUE ID | Displays an endpoint’s MAC address delimited with hyphens instead of colons. This field can be incorporated into the automatic naming convention for endpoints. Possible values:
