Hidden OSD Menus and Settings¶
The PCoIP Zero Client can be further secured by hiding certain OSD menu options and by enabling certain options via the Management Console. These configurations can not be done from the PCoIP Zero Client OSD or AWI. An administrator can choose to hide OSD menu items, or activate features like Local Administrative Password.
The profile settings that hide menus are found under the profile SECURITY section. Select and enable one or all of the following options.
Hidden OSD Menu Entries¶
Options/Configuration
Options/Diagnostics
Options/Information
Options/User Settings
Options/Password
Hide the Options menu
Options
All Menus
Hidden PCoIP Zero Client OSD User Setting Tab Entries:¶
Options > User Settings > Certificate
Options > User Settings > Mouse
Options > User Settings > Keyboard
Options > User Settings > Image
Options > User Settings > Display Topology
Options > User Settings > Touch Screen
Options > User Settings > Tablet
Options > User Settings > Region
Options > User Settings > User Interface
These are other profile settings that are not found on your PCoIP Zero Client or Remote Workstation Card and sometimes not available by default:
