Managing Endpoints¶
This section contains the following topics:
Understanding the PCoIP Management Console Dashboard: Describes the information you can view from the PCoIP Management Console DASHBOARD page.
Changing the Web Interface Time Zone: Explains how to change the PCoIP Management Console web interface time zone. By default, the web interface uses the PCoIP Management Console’s Coordinated Universal Time (UTC). For convenience when you create schedules, you can update your user account to display the web interface in your own local time zone.
The actions you can perform from the ENDPOINTS page are listed in the following table: Lists all the actions you can perform from the ENDPOINTS page and provides links to instructions for each one.
Displaying Endpoint Properties: Shows how to select the endpoint properties you wish to include in a GROUPED or UNGROUPED endpoint table.
Using the ENDPOINT DETAILS Page: Lists all the actions you can perform from the ENDPOINT DETAILS page and provides instructions for each one.
Performing Power Management: Explains how to power down and reset endpoints remotely.
Renaming Endpoints: Explains how to rename an endpoint from the ENDPOINTS page.
Deleting Endpoints: This topic explains how to delete endpoints.
Discovering Endpoints Manually: Provides information about how to use the PCoIP Management Console’s manual endpoint discovery feature.
Searching an Endpoint Table: Explains how to use a text search to locate endpoints in a GROUPED or UNGROUPED endpoint table.
Filtering the Endpoint List: Explains how to use PCoIP Management Console filters to refine the endpoints that display in a GROUPED or UNGROUPED endpoint table.
Requesting Endpoint Certificates Using SCEP (Enterprise): Available in PCoIP Management Console Enterprise. Explains how to simplify the retrieval and installation of digital certificates by enabling devices to obtain certificates automatically from a SCEP server.
