Skip to content
Configuring firewalld after a Management Console Upgrade
In Management Console releases 19.05 through 20.01, installation disabled firewalld, enabled iptables and created rules that allowed Management Console to work as expected. Starting with release 20.04, Management Console upgraded to firewalld, and leaves the firewall configuration in the hands of the local administrator.
If you are upgrading from Management Console release 19.05 through 20.01 to release 20.04 or newer using Management Console RPM, existing firewall configurations can be left intact or if moving to firewalld they will have to be re-applied to the upgraded version of Management Console.
If you decide to use firewalld, the following instructions provide the steps to remove the iptables configuration applied by Management Console and steps to add firewalld rules required by Management Console to operate properly. Additional rules required to comply to your corporate security policy must be added by the administrator.
Upgrade Scenarios discussed in this topic are:
Firewall changes after a RPM Upgrade from Management Console 20.01 or older using IPv4
Firewall changes for RPM Upgrades from Management Console 20.04 to Management Console 20.07 or newer in IPv4 Deployments
Firewalld IPv4 Script
Firewall changes required after an Upgrade from Management Console 20.01 or older to Management Console 20.07 or newer in an IPv6 Deployment
Firewalld Script for IPv6
Firewall changes required after an RPM Upgrade from Management Console 20.04 to Management Console 20.07 or newer in IPv6 Deployment
Firewall changes required after updating a Management Console OVA IPv4 deployment to an IPv6 Deployment
Firewall changes required when changing an existing Management Console IPv4 deployment to an IPv6 Deployment
Upgrades in IPv4 Environments
When upgrading from a Management Console 20.01 or older installation using RPM, consideration for all previous installation firewall rules must be considered. The following steps will remove previously installed Management Console iptables IPv4 rules and add firewalld IPv4 rules so Management Console can operate properly in an IPv4 environment.
  1. Login to Management Console host operating system console.
  2. Check iptables status(which should be active).
    sudo systemctl status iptables
    Iptables Status
  3. Check the applied iptables rules.
    sudo iptables -L
    Iptables Rules
  4. Remove rule which enabled port 8080.
    sudo iptables -D INPUT -p tcp -m state --state NEW --dport 8080 -j ACCEPT
  5. Remove rule which enabled port 8443.
    sudo iptables -D INPUT -p tcp -m state --state NEW --dport 8443 -j ACCEPT
  6. Remove rule which enabled port 5172.
    sudo iptables -D INPUT -p tcp -m state --state NEW --dport 5172 -j ACCEPT
  7. Remove rule which allowed incoming and outgoing pings.
    sudo iptables -D INPUT -p icmp --icmp-type echo-request -j ACCEPT
    sudo iptables -D OUTPUT -p icmp --icmp-type echo-reply -j ACCEPT
    sudo iptables -D OUTPUT -p icmp --icmp-type echo-request -j ACCEPT
    sudo iptables -D INPUT -p icmp --icmp-type echo-reply -j ACCEPT
  8. Remove PREROUTING rule.
    sudo iptables -t nat -D PREROUTING -i `ip addr show | grep "state UP" | head -1 | awk -F': ' '{print $2}'` -p tcp --dport 443 -j REDIRECT --to-port 8443
  9. Drop incoming packets to 127/8 from other interfaces other than loopback interface.
    sudo iptables -D INPUT -i lo -j ACCEPT
    sudo iptables -D INPUT -i lo -d 127.0.0.0/8 -j REJECT
  10. Remove outbound traffic rule.
    sudo iptables -D OUTPUT -j ACCEPT
  11. Remove logging rule.
    sudo iptables -D INPUT -m limit --limit 5/min -j LOG --log-prefix "iptables denied: " --log-level 7
  12. Remove rule which dropped packets not matching any other rule.
    sudo iptables -D INPUT -j DROP
    sudo iptables -D FORWARD -j REJECT
  13. Save iptables service to save your changes (should show status OK).
    sudo service iptables save
  14. Restart iptables to apply your changes.
    sudo systemctl restart iptables
  15. Check iptables rules (should not contain rules which Management Console install previously added).
    sudo iptables -L
    Check iptables Rules
  16. Mask iptables.
    sudo systemctl mask iptables
  17. Stop iptables service.
    sudo systemctl stop iptables
  18. Unmask firewalld, (should show removed symlink).
    sudo systemctl unmask firewalld
    Unmasked Firewalld
  19. Enable firewalld.
    sudo systemctl enable firewalld --now
  20. Start firewalld.
    sudo systemctl start firewalld
  21. Check firewalld status (should be active).
    sudo systemctl status firewalld
    Check firewalld Status
    1. Get the default zone. If the default zone is trusted it will allow all packets. It is recommended that the default zone is set to public.
      sudo firewall-cmd --get-default
      If default zone is not public, execute the following commands to set the default zone to public.
      1. sudo firewall-cmd --permanent --zone=trusted --remove-service=pcoip-agent
      2. sudo firewall-cmd --set-default=public
      3. sudo firewall-cmd --reload
  22. Get the default zone and assign it to a variable.
    def_zone=$(firewall-cmd --get-default)
  23. Set the log.(all denied packets logged together)
    sudo firewall-cmd --set-log-denied=all
  24. Add an interface.
    sudo firewall-cmd --zone=$(echo $def_zone) --change-interface=$(ip addr show | grep "state UP" | head -1 | awk -F': ' '{print $2}')
  25. Enable required ports.
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-port={80,443,22,5172}/tcp
  26. Allow pings.
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --remove-icmp-block={echo-reply,echo-request} 2>/dev/null
  27. Redirect port 443 to 8443.
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-forward-port=port=443:proto=tcp:toport=8443
  28. Enable IP Masquerading.
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-masquerade
  29. Redirect Port 80 to 8080.
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-forward-port=port=80:proto=tcp:toport=8080
  30. Drop incoming packets to 127/8 from other interfaces other than loopback interface.
    sudo firewall-cmd --permanent --new-zone loopback 2>/dev/null
    sudo firewall-cmd --permanent --zone=loopback --change-interface=lo 2>/dev/null
    sudo firewall-cmd --zone=loopback --permanent --set-target=ACCEPT
    sudo firewall-cmd --zone=loopback --permanent --add-source=127.0.0.0/8
  31. Reload the firewall rules.
  32. Confirm the rules are applied.
    1. Check the firewalld status is active.
      Firewalld Active Status
    2. Verify all rules are added in firewalld, all rules should be applied.
      sudo firewall-cmd --list-all
      Firewalld Listed Rules
Upgrading from an operational Management Console 20.04 to Management Console 20.07 or newer in an IPv4 environment does not require any firewalld rule changes.
Confirm iptables service has been disabled
It is a good idea to confirm any previous Management Console iptables installation has been removed if your 20.04 version has been previously upgraded from an older version.
HP has provided instructions to create a script that will apply firewalld rules that allow Management Console to work correctly in an IPv4 environment.
Instructions on creating and executing the script can be found here
Upgrades in IPv6 Environments
When upgrading from a Management Console 20.01 or older installation using RPM, consideration for previous installation firewall rules must be considered. The following steps will remove previously installed iptables IPv4 rules and add firewalld IPv6 rules so Management Console can operate properly in an IPv6 environment.
    Iptables Status
    sudo iptables -L
    Iptables Rules
    sudo iptables -L
  16. Mask iptables.
    Unmasked Firewalld
    sudo firewall-cmd --permanent --zone=$(echo $def_zone) --change-interface=`ip addr show | grep "state UP" | head -1 | awk -F': ' '{print $2}'`
  26. Open required ports.
    • IPv6 Port 443
      sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 port port=443 protocol=tcp accept'
    • IPv6 Port 22
      sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 port port=22 protocol=tcp accept'
    • IPv6 Port 5172
      sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 port port=5172 protocol=tcp accept'
    • IPv6 Port 80
      sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 port port=80 protocol=tcp accept'
  27. Allow pings.
  28. Redirect port 443 to 8443.
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 forward-port to-port=8443 protocol=tcp port=443'
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 forward-port to-port=8080 protocol=tcp port=80'
HP has provided instructions to create a script that removes Management Console iptables rules, stops the iptables service, and enables firewalld with the required rules for Management Console to work correctly in an IPv6 deployment.
The script file is created and executed using the following steps:
  1. Copy the script content and save into firewalld.sh
    sudo vi firewalld.sh
    #!/bin/bash
    val1=1
    if [ $val1 -eq 1 ]; then
    systemctl stop iptables || service iptables stop
    if [ $def_zone != "public" ] ; then
    fi
    firewall-cmd --zone=$(echo $def_zone) --permanent --remove-port={22,443,80,5172}/tcp # Closes 22, 443, 80, 5172 port IPv4 rules
    firewall-cmd --zone=$(echo $def_zone) --permanent --remove-forward-port=port=443:proto=tcp:toport=8443  # Removes IPv4 internal port forwarding from 443 to 8443
    firewall-cmd --zone=$(echo $def_zone) --permanent --remove-forward-port=port=80:proto=tcp:toport=8080   # Removes IPv4 internal port forwarding from 80 to 8080
    firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 port port=443 protocol=tcp accept'                  # Open 443 port IPv6  rules
    firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 port port=22 protocol=tcp accept'                   # Open 22 port IPv6  rules
    firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 port port=5172 protocol=tcp accept'                 # Open 5172 port IPv6  rules
    firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 port port=80 protocol=tcp accept'                   # Open 80 port IPv6  rules
    firewall-cmd --zone=$(echo $def_zone) --permanent --remove-icmp-block={echo-reply,echo-request}                                         # Allow icmp ping reply and request
    firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 forward-port to-port=8443 protocol=tcp port=443'    # Forward IPv6 443 port to 8443
    firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 forward-port to-port=8080 protocol=tcp port=80'     # Forward IPv6 80 port to 8080
    firewall-cmd --zone=loopback --permanent --add-source=127.0.0.0/8  # Not removing loopback as some services require loopback address to function properly
    firewall-cmd --reload          # Reload the firewall tables
    fi 2> /dev/null
  2. Provide permissions for the script to execute.
    sudo chmod +x ./firewalld.sh
  3. Run firewalld.sh:
    sudo ./firewalld.sh
Firewall changes required after an RPM Upgrade from Management Console 20.04 to Management Console 20.07 or newer in an IPv6 Deployment
When upgrading from IPv4 to IPv6, firewalld IPv4 rules must be replaced with IPv6 rules.
Perform the following steps to ensure Management Console only has IPv6 rules enabled after upgrading from an IPv4 environment.
  1. Login to Management Console operating system console using an SSH client (e.g. PuTTY).
  2. Ensure firewalld is enabled.
  3. Get the default zone. If the default zone is trusted it will allow all packets. It is recommended that the default zone is set to public.
  4. Get the default zone and assign it to a variable.
  5. Close IPv4 ports 22, 443, 80, and 5172.
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --remove-port={22,443,80,5172}/tcp
  6. Remove IPv4 internal port forwarding from 443 to 8443.
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --remove-forward-port=port=443:proto=tcp:toport=8443
  7. Remove IPv4 internal port forwarding from 80 to 8080.
    sudo firewall-cmd --zone=$(echo $def_zone) --permanent --remove-forward-port=port=80:proto=tcp:toport=8080
  8. Set the log. (all denied packets are logged together)
  9. Add an interface.
  10. Open required ports.
    • IPv6 Port 443
    • IPv6 Port 22
    • IPv6 Port 5172
    • IPv6 Port 80
  11. Allow pings.
  12. Redirect port 443 to 8443.
  13. Redirect Port 80 to 8080.
  14. Drop incoming packets to 127/8 from other interfaces other than loopback interface.
  15. Reload the firewall rules.
  16. Confirm the rules are applied.
To use Management Console OVA in an IPv6 environment, the firewall rules for IPv4 should be removed and the IPv6 rules must be added so Management Console can communicate properly.
Once Management Console 20.07 or newer is deployed, log into it's host operating system console and perform the following steps.
  1. Close IPv4 ports 22, 443, 80, and 5172.
  2. Remove IPv4 internal port forwarding rules.
    • From port 443 to 8443.
    • From port 80 to 8080.
  3. Open required IPv6 ports.
    • IPv6 Port 443
      sudo firewall-cmd --zone=$(echo $def_zone) --permanent --add-rich-rule='rule family=ipv6 port port=443 protocol=tcp accept'`
    • IPv6 Port 22
    • IPv6 Port 5172
    • IPv6 Port 80
  4. Redirect required ports.
    • Port 443 to 8443
    • Port 80 to 8080
  5. Reload firewall rules.
