Deleted Data When Migrating between IP Protocols¶
After migrating from an IPv4 network to an IPv6 network (or vice versa), Management Console deletes data related to the removed IP version.
This table provides descriptions of data that is deleted and uses an example of a migration from IPv4 to IPv6.
IPv6 to IPv4 migrations
Similarly, IPv6 data is deleted when migrating from IPv6 to IPv4.
Tab Name Migration Behavior |
Display Before Migration |
Display After Migration |
Dashboard The data related to IPv4 endpoints will not be restored. Schedule data is restored. |
Endpoints All the groups will be restored. IPv4 endpoints will be deleted. |
Profile All profiles will be restored |
Schedule All schedules will be restored |
Auto Configuration Autoconfig rules related to IPv4 IP Ranges will be deleted. |
Endpoint Certificates All Endpoint Certificates will be restored. |
Authentication All users will be restored. |
Active Directory Configuration IPv4 Active Directory Configuration will not be restored |
Remote Configuration In Remote Configuration, IPv4 related Local IP Address ranges will not be restored |
Software All softwares will be restored. |
