Skip to content
PCoIP Management Console 1 Profile Properties Renamed or Not Migrated
The following table lists PCoIP Management Console 1 profile properties that have been renamed PCoIP Management Console Enterprise or Free and are not migrated when you import a PCoIP Management Console 1 profile to a current release of PCoIP Management Console.
Reference to PCoIP Management Console refer to this release or later releases, unless otherwise specified.
Migrating and renaming notes
In the next table, when a PCoIP Management Console 1 property is not migrated, its Migration Notes column will have an explanation. If this column is blank, then the property only has a name change in the new PCoIP Management Console. Some properties that are currently not migrated may be included in future PCoIP Management Console releases.
PCoIP Management Console 1 Profile Information Renamed or Not Migrated
Release 1 Category Release 1 Property Name Current Release Category Current Release Property Name Migration Notes
Network Configuration SNMP NMS Address Network Trap NMS Address Not migrated when PCoIP Management Console 1 property Network Configuration > Enable SNMP is not Set in Profile or is set to False
Network Configuration Enable SNMP Cold Start Trap Network SNMP Cold Start Trap Not migrated when PCoIP Management Console 1 property Network Configuration > Enable SNMP is not Set in Profile or is set to False.
Network Configuration Enable SNMP V1 Traps Network SNMP V1 Traps Not migrated when PCoIP Management Console 1 property Network Configuration > Enable SNMP is not Set in Profile or is set to False.
Network Configuration Enable SNMP V2c Traps Network SNMP V2 Traps Not migrated when PCoIP Management Console 1 property Network Configuration > Enable SNMP is not Set in Profile or is set to False.
Network Configuration SNMP Community Name Network SNMP Community Name Not migrated when PCoIP Management Console 1 property Network Configuration > Enable SNMP is not Set in Profile or is set to False.
Network Configuration Static Fallback IP Address Network Static Fallback IPv4 Address Not migrated when PCoIP Management Console 1 property Network Configuration> Enable SNMP is not Set in Profile or is set to False.
Network Configuration Static Fallback Subnet Mask Network Static Fallback IPv4 Subnet Mask Not migrated when PCoIP Management Console 1 property Network Configuration > Enable SNMP is not Set in Profile or is set to False.
Network Configuration Static Fallback Gateway Address Network Static Fallback IPv4 Gateway Not migrated when PCoIP Management Console 1 property Network Configuration > Enable SNMP is not Set in Profile or is set to False.
Network Configuration Static Fallback Timeout Network Static Fallback IPv4 Timeout Not migrated when PCoIP Management Console 1 property Network Configuration > Enable SNMP is not Set in Profile or is set to False.
Discovery Configuration PCoIP Management Console DNS-Based Discovery Prefix Never migrated. Not used in firmware 5.0.0 and later.
Session Configuration PCoIP Connection Manager Server Address Session > Session Type Server URI Not migrated when PCoIP Management Console 1 property Session Configuration > Session Connection Type is not Set in Profile or is not set to one of the following:
  • PCoIP Connection Manager
  • PCoIP Connection Manager + Auto-Logon
  • Session Configuration Auto Detect Server URI Session > Session Type Server URI Not migrated when PCoIP Management Console 1 property Session Configuration > Session Connection Type is not Set in Profile or is not set to Auto Detect.
    Session Configuration Auto-Logon Username Session > Session Type Logon Username Not migrated when PCoIP Management Console 1 property Session Configuration > Session Connection Type is not Set in Profile or is not set to one of the following:
  • View Connection Server + Auto-Logon
  • Session Configuration Auto-Logon Password Session > Session Type Logon Password Not migrated when PCoIP Management Console 1 property Session Configuration > Session Connection Type is not Set in Profile or is not set to one of the following:
  • Session Configuration Auto-Logon Domain Session > Session Type Logon Domain Name Not migrated when PCoIP Management Console 1 property Session Configuration > Session Connection Type is not Set in Profile or is not set to one of the following:
  • Session Configuration Enable View Connection Server SSL Never migrated. Not used in firmware 4.x and later.
    Session Configuration Kiosk Mode Custom Username Session > Session Type Username Not migrated when PCoIP Management Console 1 property Session Configuration > Session Connection Type is not Set in Profile or is not set to View Connection Server + Kiosk.
    Session Configuration Kiosk Mode Password Session > Session Type Password Not migrated when PCoIP Management Console 1 property Session Configuration > Session Connection Type is not Set in Profile or is not set to View Connection Server + Kiosk.
    Session Configuration Organization ID Never migrated. Currently not included in PCoIP Management Console.
    Session Configuration OneSign Direct to View Address Never migrated. Currently not included in PCoIP Management Console.
    Session Configuration Disconnect Dialog Display Mode Session > Session Type Disconnect Message Filter
    Session Configuration Enable Login Username Caching Session > Session Type Remember Username
    Session Configuration Prefer GSC-IS Over PIV Endpoint Session > Session Type Prefer GSC-IS
    Session Configuration Proximity Reader Beep Mode Session > Session Type Pre-Session Reader Beep
    Encryption Configuration Enable Salsa20-256-Round12 Encryption Never migrated. Applies to Tera1 endpoints only.
    Encryption Configuration Enable AES-128-GCM Encryption Never migrated. Not configurable in FW 5.0.0 and later.
    Encryption Configuration Enable AES-256-GCM Encryption Never migrated. Not configurable in FW 5.0.0 and later.
    Encryption Configuration Session Negotiation Security Level Session > Session Type Session Negotiation Cipher
    OSD Configuration Hidden Menu Entries Security Hidden OSD Menu Entries
    Image Configuration Low Bandwidth Text Codec Mode Never migrated. Currently not included in PCoIP Management Console.
    Image Configuration Enable Client Image Settings Never migrated. Remote Workstation Card property.
    Display Configuration Enable Monitor Emulation on Video Port 1-4 Never migrated. Remote Workstation Card property.
    Display Configuration Enable Host Hot-Plug Delay Never migrated. Remote Workstation Card property.
    Display Configuration Enable Display Cloning Session > Display Configuration Clone Primary Display
    Display Configuration Enable Accelerated Monitor Emulation Never migrated. Remote Workstation Card property.
    Time Configuration Enable DST Other > Time Daylight Saving Time
    Time Configuration Time Zone Offset Other > Time Time Zone Converted to IANA zoneinfo time zone. See Time Zone Definitions for PCoIP Management Console 1 or 2
    Security Configuration Password Security Local Administrative Password
    Security Configuration Enable Password Protection Security Enable Password Protection for OSD and AWI
    Security Configuration Enable 802.1X Support for Legacy Switches Security 802.1X Legacy Support
    Audio Permissions Enable Vista/Windows 7 64-bit Mode Never migrated. Remote Workstation Card property
    Audio Permissions Enable Audio Line In Never migrated. Remote Workstation Card property
    Audio Permissions Dual Audio Output Mode Dual Audio Output Migrated in PCoIP Management Console 19.11.
    Audio Permissions Audio In Device Type Session > Audio Input Audio Device Type
    Audio Permissions Audio In Preferred USB Vendor ID Session > Audio Input Preferred USB Vendor ID
    Audio Permissions Audio In Preferred USB Device Product ID Session >Audio Input Preferred USB Device Product ID
    Audio Permissions Audio Out Device Type Session > Audio Output Audio Device Type
    Audio Permissions Audio Out Preferred USB Vendor ID Session > Audio Output Preferred USB Vendor ID
    Audio Permissions Audio Out Preferred USB Device Product ID Session / Audio Output Preferred USB Device Product ID
    Power Permissions Client Power Button Function Power Remote Host Power Control
    Power Permissions Wake-on-USB Mode Power Wake-on-USB
    Power Permissions Wake-on-LAN Mode Power Wake-on-LAN
    Power Permissions Power On After Power Loss ModeA Power Power On After Power Loss
    Power Permissions Client Power Down Timeout Seconds power Auto Power-Off Timeout
    Power Permissions Display Suspend Timeout Seconds Power Display Suspend Timeout
    Host Driver Configuration Enable Host Driver Never migrated. Remote Workstation Card property.
    Event Log Control Enable Diagnostic Log Never migrated. Not used in firmware 5.0.0 and later.
    Event Log Control Event Log Filter Mode Never migrated. Not used in firmware 5.0.0 and later.
    Event Log Control Syslog Facility Number Logging Syslog Facility
    Event Log Control Enhanced Logging Mode Mask Logging Enhanced Logging Mode Not migrated when PCoIP Management Console 1 is configured to Enhanced logging disabled.
    Peripheral Configuration Enable USB EHCI Peripheral EHCI
    Peripheral Configuration Force Local Cursor Visible Peripheral Force Local Cursor Visibility Migrated in MC 3.2
    Peripheral Devices Forced to USB 1.1 Migrated in MC 3.2. This feature is available in firmware 5.0+
    IPv6 Configuration IPv6 Domain Name Network IPv6 Domain Name Not migrated when PCoIP Management Console 1 property IPv6 Configuration > Enable IPv6 is not Set in Profile or is set to False
    IPv6 Configuration Enable DHCPv6 Network DHCPv6 Not migrated when PCoIP Management Console 1 property IPv6 Configuration > Enable IPv6 is not Set in Profile or is set to False
    IPv6 Configuration Enable SLAAC Network SLAAC Not migrated when PCoIP Management Console 1 property IPv6 Configuration > Enable IPv6 is not Set in Profile or is set to False
    IPv6 Configuration IPv6 Gateway Address IPv6 Gateway Address Prefix Length Network IPv6 Gateway
    IPv6 Configuration IPv6 Primary DNS Address IPv6 Primary DNS Address Prefix Length Network Primary IPv6 DNS
    IPv6 Configuration IPv6 Secondary DNS Address IPv6 Secondary DNS Address Prefix Length Network Secondary IPv6 DNS
    SCEP Configuration SCEP Server URI Never migrated. Currently not included in PCoIP Management Console
    SCEP Configuration Challenge Password Never migrated. Currently not included in PCoIP Management Console
    SCEP Configuration Use Certificate for 802.1X Never migrated. Currently not included in PCoIP Management Console
    Display Configuration Preferred Override Resolution on Port 1-4 Session > Display Configuration: Video Port 1-4 Preferred Resolution Not migrated when PCoIP Management Console 1 property Preferred Resolution is set to Native
    Display Topology Configuration (Dual and Quad) Display Layout Alignment Session > Display Configuration: Dual/Quad Display Topology Display Layout Alignment Not migrated when PCoIP Management Console 1 property Display Topology Configuration > Enable Configuration is not Set in Profile or is set to False
    Display Topology Configuration (Dual and Quad) Primary Port Session > Display Configuration: Dual/Quad Display Topology Primary Port Not migrated when PCoIP Management Console 1 property Display Topology Configuration > Enable Configuration is not Set in Profile or is set to False
    Display Topology Configuration (Dual and Quad) Position Session > Display Configuration: Dual/Quad Display Topology Position Not migrated when PCoIP Management Console 1 property Display Topology Configuration > Enable Configuration is not Set in Profile or is set to False
    Display Topology Configuration (Dual and Quad) Rotation Session > Display Configuration: Dual/Quad Display Topology Rotation Not migrated when PCoIP Management Console 1 property Display Topology Configuration > Enable Configuration is not Set in Profile or is set to False
    Display Topology Configuration (Dual and Quad) Resolution Session > Display Configuration: Dual/Quad Display Topology Resolution Not migrated when PCoIP Management Console 1 property Display Topology Configuration > Enable Configuration is not Set in Profile or is set to False
    Profile OSD Logo Other > OSD OSD Logo Never migrated
    Profile Firmware Software Firmware Version
    Image Configuration Low Bandwidth Text Codec Mode Image Enable Low Bandwidth Text Codec Migrated value applicable only for DUAL Client device
    Image Configuration Enable Client Image Settings Image Use Client Image Settings Migrated value applies to Host (DUAL and QUAD) device only
    Display Configuration Enable Monitor Emulation on Video Port 1-4 Session Monitor Emulation: Video Port 1
    Monitor Emulation: Video Port 2
    Monitor Emulation: Video Port 3
    Monitor Emulation: Video Port 4
    Migrated values apply to Host device only. Values of port 3 and 4 are ignored for DUAL type
    Display Configuration Enable Host Hot-Plug Delay Session Host Hot-Plug Delay Migrated value applies to Host (DUAL and QUAD) device only
    Display Configuration Enable Display Cloning Session > Monitor Emulation Clone Primary Display Applies to Client DUAL devices only
    Display Configuration Enable Accelerated Monitor Emulation Session > Monitor Emulation Accelerated Monitor Emulation Migrated value applies to Host (DUAL and QUAD) device only
    Audio Permissions Enable Vista/Windows 7 64-bit Mode Never migrated. Applied to Tera1 devices
    Audio Permissions Enable Audio Line In Session > Audio Audio Line In
    Audio Permissions Audio In Device Type Session > Audio Input Audio Device Type Migrated value applies to Client (DUAL and QUAD) device only
    Audio Permissions Audio In Preferred USB Vendor ID Session > Audio Input Preferred USB Vendor ID Migrated value applies to Client (DUAL and QUAD) device only
    Audio Permissions Audio In Preferred USB Device Product ID Session > Audio Input Preferred USB Device Product ID Migrated value applies to Client (DUAL and QUAD) device only
    Audio Permissions Audio Out Device Type Session > Audio Output Audio Device Type Migrated value applies to Client (DUAL and QUAD) device only
    Audio Permissions Audio Out Preferred USB Vendor ID Session > Audio Output Preferred USB Vendor ID Migrated value applies to Client (DUAL and QUAD) device only
    Audio Permissions Audio Out Preferred USB Device Product ID Session > Audio Output Preferred USB Device Product ID Migrated value applies to Client (DUAL and QUAD) device only
    Power Permissions Client Power Button Function Power Remote Host Power Control Migrated value applies to Client (DUAL and QUAD) device only
    Only the following values from MC1 are migrated, e rest are no longer supported in MC 3
    The user can only invoke a hard power off
    The user cannot invoke any power off
    Power Permissions Wake-on-LAN Mode Power Wake-on-LAN Migrated value applies to Host (DUAL and QUAD) device only
    Power Permissions Power On After Power Loss Mode Power Power On After Power Loss Migrated value applies to Client (DUAL and QUAD) device only
    Power Permissions Client Power Down Timeout Seconds Power Auto Power-Off Timeout Migrated value applies to Client (DUAL and QUAD) device only
    Power Permissions Display Suspend Timeout Seconds Power Display Suspend Timeout Migrated value applies to Client (DUAL and QUAD) device only
    Host Driver Configuration Enable Host Driver Host Driver Host Driver Migrated value applies to Host (DUAL and QUAD) device only
    Peripheral Configuration Enable USB EHCI Peripheral EHCI Migrated value applies to Client (DUAL and QUAD) device only
    SCEP Configuration SCEP Server URI Never Migrated. Included under ENDPOINT CERTIFICATES IN mc 3.1
    SCEP Configuration Challenge Password Never Migrated. Included under ENDPOINT CERTIFICATES IN mc 3.1
    SCEP Configuration Use Certificate for 802.1X Never Migrated. Included under ENDPOINT CERTIFICATES IN mc 3.1
    Display Topology Configuration (Dual and Quad) Primary Port "Session > Monitor emulation: Quad Display Session > Monitor Emulation Dual Display" Position "Not migrated when PCoIP Management Console 1 property Display Topology Configuration > Enable Configuration is not Set in Profile or is set to False.
    Display Topology Configuration (Dual and Quad) Rotation "Session > Monitor emulation: Quad Display Session > Monitor Emulation Dual Display" Rotation "Not migrated when PCoIP Management Console 1 property ''Display Topology Configuration > Enable Configuration is not Set in Profile or is set to False.
    Migrated value applies to Client device only. Values for Port 3 and 4 ignored for DUAL display"
    Display Topology Configuration (Dual and Quad) Resolution "Session > Monitor emulation: Quad Display Session > Monitor Emulation Dual Display" Resolution "Not migrated when PCoIP Management Console 1 property Display Topology Configuration > Enable Configuration is not Set in Profile or is set to False.
    Profile Firmware Software Never migrated. All migrated profiles are assigned to appropriate PCoIP Zero Client or Hard Host firmware
    In addition to the previous table, the following table lists properties that are also not migrated when you import a PCoIP Management Console 1 profile, because they are not managed by the PCoIP Management Console newer releases.
    PCoIP Zero Client Properties not Managed by the PCoIP Management Console
    Firmware Property Firmware Version Description
    Prefer IPv6 FQDN Resolution 4.8.0 Not managed by PCoIP Management Console 1.x or later releases of PCoIP Management Console
    IPv6 Address Resolution 4.8.0 Not managed by PCoIP Management Console 1.x or later releases of PCoIP Management Console
    OSD Region Tab Lockout 5.0.0 Never managed by PCoIP Management Console 1.x
