Installing the PCoIP Management Console and Configuring Your System¶
The topics in this section contain information to help you get up and running quickly.
Topics that refer to specific versions of PCoIP Management Console will be identified by the release number.
Migrating, upgrading, or downgrading from other versions
If you are migrating to a new PCoIP Management Console version see Migrating to a Newer Version. If you need to downgrade endpoints from firmware 20.01 or higher to an older version, see Downgrading Endpoints to Older Firmware.
Installation Overview¶
PCoIP Management Console is released in two formats. The first called Open Virtual Appliance (OVA) format with supported hypervisor platforms of VMware ESXi 7.0 and 8.0. The second format is RPM which is one standard for Linux Administrators to manage software installations.
OVA installation contain all dependencies required for Management Console and provide for an easy first time install.
RPM upgrade may require the installation of a dependency package for RHEL 8, Rocky Linux 8, RHEL 9 and Rocky Linux 9 deployments. If required, these packages will be available from the support site download area and may change with each release. To obtain a supported download, go to the version of Management Console you require and download the available download required for your deployment.
