About Certificates¶
Certificates can be used to trust endpoint managers at all security levels, but are required when using medium or high security.
If a PCoIP Management Console certificate is required, you can use an issuer certificate—either the root CA certificate, or the leaf certificate used to issue the PCoIP Management Console’s public key certificate—or the PCoIP Management Console’s public key certificate.
Customer peer-to-peer certificates can also be used to secure PCoIP Zero Clients connecting to Remote Workstation Cards in your deployment. See Peering Remote Workstation Cards to PCoIP Zero Clients and Uploading Certificates for further details on how to upload and apply peer-to-peer certificates.
OCSP (Online Certificate Status Protocol)
OCSP (Online Certificate Status Protocol) is currently not supported on PCoIP Remote Workstation Cards.
