Configuring the Label Settings¶
The Label page lets you assign a device name to your PCoIP device for easy reference. You can access this page for the host card from the Configuration > Label menu.
AWI Label Page Parameters
Parameter | Description |
PCoIP Device Name | Lets you give the host a logical name. The default is pcoip-host- This field is the name the host registers with the DNS server if DHCP is enabled and the system is configured to support registering the hostname with the DNS server. It's important to ensure that the PCoIP Device Name is unique for each endpoint in the network and follows these naming conventions: |
PCoIP Device Description | A description of the device or other information, such as the location of the device's endpoint. Note: The firmware does not use this field. It is provided for administrator use only. |
Generic Tag | Generic tag information about the device. Note: The firmware does not use this field. It is provided for administrator use only. |
