Configuring the Management State¶
The PCoIP Remote Workstation Card can be managed by an endpoint managers such as the PCoIP Management Console should one be available on the network. The AWI Management page tells the host card how to find the manager based on predetermined network deployment security levels. Configuring the security levels for endpoint managers is described in Configuring Endpoint Management Discovery Methods with further information on certificates required for each level of secure configuration found in the PCoIP Remote Workstation Card Security Overview.
From the AWI, you can set the PCoIP Remote Workstation Card's management state to automatic or manual modes.
AWI Management page – automatic discovery mode
AWI Management page – manual discovery mode
Clearing the Management State¶
Setting | Default | AWI | Management Console |
Clear Management State (a button) | − | ✓ | ✓ |
Clearing the management state removes the current endpoint manager information for the PCoIP Remote Workstation Card. Once the Remote Workstation Card is managed by an endpoint manager, you must clear its management state before the PCoIP device can accept a new endpoint manager.
You clear the management state from the AWI Management pages.
Discovery settings determine what displays on the AWI Management page
The information that displays on the AWI Management page depends on whether the PCoIP Remote Workstation Card uses automatic or manual discovery.
To clear the management state:
From the OSD or AWI, select Configuration > Management.
From the OSD or AWI Management page, click Clear Management State so that the endpoint will accept a new endpoint manager.
To save your updates, click OK from the OSD, or click Apply from the AWI.
