Upload a Firmware Release to a Remote Workstation Card¶
To upload a firmware release to a PCoIP Remote Workstation Card:
Ensure the host PC is in an idle state (i.e., that all applications are closed).
Log into the host's AWI.
From the Firmware Upload page, browse to the folder containing the firmware file. This file will have an ".all" extension.
Double-click the correct "*.all" firmware file.
Click Upload.
Click OK to confirm that you want to proceed with the upload. The operation may take a few minutes. When completed, the AWI page displays two buttons—Reset and Continue.
Click Reset.
Click OK.
Power off and then power on the host PC. It is necessary to power off (not just restart) the PC or workstation in order for the changes to take effect on the Remote Workstation Card.
