Using an Endpoint Manager¶
An installed certificate is required to connect to an endpoint manager in medium or high security levels; however, out of the box, the PCoIP Remote Workstation Card‘s local certificate store is empty and it can only connect using the low security level.
To deploy a system using medium or high security settings, you must stage the device by connecting to an endpoint manager in low security mode and installing any required certificates or installing the certificate from the AWI.
Once the certificate has been installed, you can connect using any security level.
In some deployments, administrators choose to remove administration of the PCoIP Remote Workstation Card by the PCoIP Management Console or AWI which adds an additional layer of security.
