Configuring Initial Setup Parameters¶
Before you use your Tera2 PCoIP Zero Client for the first time, you need to configure initial setup parameters, including setting basic audio, network, and session information.
You can perform this initial setup from the AWI Initial Setup page, shown next.
The following parameters display on the AWI Initial Setup page:
Audio Parameters
Category | Parameter | Description |
Audio | Enable HD Audio | Enables audio support on the client |
Network | Enable DHCP | Enables DHCP (as opposed to using manual IP address configuration) |
IP Address | Device’s IP address | |
Subnet Mask | Device’s subnet mask | |
Gateway | Device’s gateway IP address | |
Primary DNS Server | Device’s primary DNS IP address | |
Secondary DNS Server | Device’s secondary DNS IP address |
You can also configure network settings from the OSD and AWI Network and Audio pages
You can configure the initial setup settings, as well as other network settings, from the OSD and AWI Network pages. To configure network settings from these pages, see Configuring Audio and Configuring Network Settings.
Session Parameters
Session parameters are configured from the AWI Configuration -> Session page.
To configure initial setup parameters from the AWI:
From the AWI, select Configuration > Initial Setup.
From the AWI Initial Setup page, configure audio, and network parameters.
Browse to Configuration > Session and select your preferred session type.
Click Apply to save your configuration.
