Disconnecting from a Session¶
Disconnecting from a Virtual Desktop¶
You can disconnect from a virtual desktop session and return to the OSD by either of the following options.
Pressing Ctrl+Alt+F12 which requires the Enable Session Disconnect Hotkey enabled in the advanced options on the AWI Session page.
Pressing the device’s Connect/Disconnect button.
Enabling the Enable Reboot on Session Disconnect option in the session advanced settings so every session disconnect performs an automatic Zero Client power reset.
Disconnecting from a Remote Workstation Card¶
If you are in a session with a PCoIP Remote Workstation Card and if the Zero Client AWI Power Parameter Remote Host Power Control is set to Hard Power-off only, the zero client connect/disconnect button will display the Zero Client Control Panel to control session disconnects. If the Remote Host Power Control is set to Power-off not permitted, the zero client connect/disconnect button will initiate a connect or disconnect of a PCoIP session.
To make a selection, tap the Connect/Disconnect button to toggle between options until the desired one is highlighted, then wait for the four-second countdown to complete.
If you have installed and configured the Remote Workstation Card Software on the host computer, additional keyboard functionality is provided, allowing you to:
use the up/down arrow keys on the keyboard to highlight the zero client control panel desired option, and press Enter to make the selection.
use the keyboard number keys (1, 2, 3) that matches the control panel option to select it immediately.
use the Ctrl+Alt+F12 shortcut sequence to display the zero client control panel.
To ensure full functionality of the keyboard when in a session with the Remote Workstation Card ensure all the following settings are made.
On the zero client, the keyboard must be recognized as locally connected (not bridged).
The Host Driver Function is enabled on the Remote Workstation Card firmware.
The Enable Local Cursor and Keyboard feature is enabled on the installed Remote Workstation Card Software for Linux or Windows on the host computer.
The Remote Workstation Card Software for Linux or Windows is installed on the host computer and the Enable Local Cursor and Keyboard feature is enabled.
(Optional) Enable Session Disconnect Hotkey must be enabled in the advanced options on the Session page to enable the Ctrl+Alt+F12 shortcut sequence.
