Connecting the Tera2 PCoIP Zero Client to the NetworkΒΆ
To connect the Tera2 PCoIP Zero Client:
Connect a USB keyboard and mouse to any of the Tera2 PCoIP Zero Client USB ports.
Connect one end of the Ethernet cable to the Tera2 PCoIP Zero Client and the other end to a switch/router. The switch or router should be on the same network as the Remote Workstation Card or virtual desktop server if there is not a PCoIP Management Console that is managing the PCoIP endpoints.
Connect monitor cables to the Tera2 PCoIP Zero Client.
Connect monitors using correct ports
To ensure the best experience, connect monitors to the zero client ports in sequential order
Supporting 2560 x 1600 resolutions
Ensure your cables are connected as shown when configuring monitors for 2560 x 1600 resolutions. For more information see knowledge base article 1025
Single Display at 2560 x 1600 Resolution
Dual Displays at 2560 x 1600 ResolutionsConnecting to Remote Workstation Cards
For additional information when connecting monitor cables using PCoIP Remote Workstation Cards, refer to the Remote Workstation Card Administrators' Guide - Installation section
(Optional) Connect speakers and/or headphones to the Tera2 PCoIP Zero Client.
Connect the power supply to the Tera2 PCoIP Zero Client and a power source.
Press the front panel button to power on the Tera2 PCoIP Zero Client.
