Setting Up Your Tera2 PCoIP Zero Client¶
This section describes how to connect your Tera2 PCoIP Zero Client to the network. You'll also learn how to configure initial setup parameters, as well as secure your Tera2 PCoIP Zero Client so that you can establish a successful PCoIP session.
The topics include:
- Enabling the AWI
- Connecting the Tera2 PCoIP Zero Client to the Network
- Configuring Initial Setup Parameters
- Securing Your Tera2 PCoIP Zero Client
- Reset Notification
Connecting Peripherals¶
Connect USB keyboard and mouse.
Connect one end of the Ethernet cable to the zero client and the other end to a switch/router. The switch or router should be on the same network as the Remote Workstation Card or virtual desktop server. For more advanced network environments, visit the support site.
Connect monitor cables to the zero client.
Connect speakers and/or headphones (optional). Connect power supply to the zero client and a power source.
Press the front panel PCoIP button to power on the zero client after your peripherals are connected to the zero client.
Reset Notification¶
You can have your PCoIP Zero Client display a pop up message that notifies you that your PCoIP Zero Client is about to restart. This feature is beneficial when performing a remote configuration change via the AWI or a PCoIP Management Console profile update that requires the PCoIP Zero Client to reboot. Enabling this feature can provide you the time to save important work before the reboot happens. This setting can be found in the AWI Reset Parameters page and in the Management Console profile Power section.
This feature has 4 configurable options.
- 0 seconds (disabled)
- 30 seconds
- 60 seconds (1 minute)
- 300 seconds(5 minutes)
