Testing Attached Displays¶
Setting | Default | AWI | OSD | Management Console |
Test mode | Video Test Pattern Generator | ✓ | × | × |
Test resolution | 2048x1152 | ✓ | × | × |
Start (a button) | − | ✓ | × | × |
Stop (a button) | − | ✓ | × | × |
From the AWI Display page, as shown next, you can initiate and view a visual test pattern on the Tera2 PCoIP Zero Client's attached display(s).
You can't display test patterns during PCoIP sessions
The test pattern only displays when the Tera2 PCoIP Zero Client isn't in a PCoIP session. If you click Start when the Tera2 PCoIP Zero Client is in a session, an error message displays.
AWI Display page
To initiate a test pattern:
- From the AWI, select Diagnostics > Display.
From the AWI Display page, do the following:
- From the Test mode list, select the type of test pattern to display on the Tera2 PCoIP Zero Client's attached display(s).
- From the Test resolution list, select the test resolution to use.
- Click Start to display a test pattern on the Tera2 PCoIP Zero Client's attached display(s). Click Stop to stop the test.
