Skip to content
Configuring Certificate Checking Mode
Setting Default AWI OSD Management Console
Certificate Checking Mode Warn before connecting to untrusted servers ×
Certificate Check Mode Lockout Disabled ×
The Certificate Checking Mode option configures how the Tera2 PCoIP Zero Client behaves if it can't verify a secure connection to the server. You configure this setting from the OSD. To configure this setting, see Setting Certificate Checking Mode.
Enabling the Certificate Check Mode Lockout option prevents users from changing the Certificate Checking Mode option on the OSD. You enable this option from the advanced settings for any of the following session types:
