OSD: Auto Detect Session Settings¶
This connection type automatically detects which broker protocol a connection server is using so users in a mixed environment (for example, one that uses View Connection Servers and PCoIP Connection Managers) do not have to manually reconfigure the session type each time they switch brokers. Once a successful connection has been made, the server URI will automatically appear in the Server drop-down list on the user’s OSD Connect screen, along with any other desktops the user has successfully connected to. Additionally, you can use Auto Detect when connecting directly to HP Anyware.
OSD session connection type – Auto Detect
The following parameters can be found on the OSD Auto Detect page.
OSD Auto Detect Parameters
Parameter | Description |
Server URI | Enter the Uniform Resource Identifier (URI) for the PCoIP Connection Manager, Broker, or HP Anyware host. The URI must be in the form https://{ host FQDN } or https://{ ip address }. Once a successful connection has been made, it will appear in the Server drop-down list on the OSD Connect page if the Tera2 PCoIP Zero Client is configured to cache servers. |
