Skip to content
OSD: PCoIP Connection Manager Session Settings
Select the PCoIP Connection Manager session connection type from the Options > Configuration > Session page to configure the client to use a PCoIP Connection Manager as the PCoIP session broker or when connecting to a HP Anyware host.
Click the Advanced button to configure advanced settings for this option.
Alt text
OSD Session connection type – PCoIP Connection Manager
Alt text
Advanced Settings
The following parameters can be found on the OSD PCoIP Connection Manager page.
OSD PCoIP Connection Manager Parameters
Parameter Description
Server URI Enter the Uniform Resource Identifier (URI) for the PCoIP Connection Manager, Broker, or HP Anyware host.
The URI must be in the form https://{ host FQDN } or https://{ ip address }.
Desktop Name to Select Enter the desktop name used by the client when starting a session.
Auto Connect This field determines the client’s auto connect behavior after startup:
Enabled: The client automatically connects with the connection server after startup and a PCoIP session ends, bypassing the OSD Connect page.
Disabled: The client does not automatically connect with the connection server.
Enabled With Retry On Error: The client will continuously attempt to contact the connection server. After a connection failure, the client waits before attempting to connect again. This wait time increases with each successive failure. The wait interval is not configurable.
Devices running firmware 4.1.1 or lower do not support Retry On Error behavior and will always perform a single attempt to contact the connection server when this option is selected.
After enabling Auto Connect, the client must be power-cycled for the change to take effect.
Remember Username When enabled, the user name text box automatically populates with the last username entered.
Auto Launch If Only One Desktop When enabled, users are automatically connected to a provisioned desktop after user credentials are entered.
This feature only applies to users who are entitled to a single desktop. It does not apply to users entitled to multiple virtual desktops.
Use OSD Logo for Login Banner When enabled, the OSD logo banner appears at the top of login screens in place of the default banner.
Enable Peer Loss Overlay When enabled, the 'Network Connection Lost' overlay appears on the display(s) when a loss of network connectivity is detected. Normal hypervisor scheduling delays can falsely trigger this message.
Enable Preparing Desktop Overlay When enabled, the 'Preparing Desktop' overlay appears on the display(s) when users log in.
This overlay provides assurance that login is proceeding if the desktop takes more than a few seconds to appear.
Disconnect Message Filter This field lets you control what type of messages appear when a session is disconnected. There are three categories:
Information: User- or administrator-initiated actions affecting the session:
  • You have been disconnected because you logged in from another location or your host was shut down or restarted.
  • You have been disconnected because an administrator disconnected you.
  • You have been disconnected because you logged in from another location.
  • You have been disconnected because you disconnected from your workstation.
Warning: System-initiated, but expected actions affecting the session:
  • You have been disconnected because your session timed out.
Error: Unexpected system-initiated actions causing session to fail:
  • You have been disconnected.
  • Unable to connect (0x1001). Contact your IT administrator.
  • Unable to connect (0x1002). Contact your IT administrator.
  • Session closed remotely.
  • Session closed remotely (unknown cause).
  • You have been disconnected due to a configuration error (0x100). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x201). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x300). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x301). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x302). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x303). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x305). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x400). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x401). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x402). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x403). Contact your IT administrator for assistance.
  • You have been disconnected due to a configuration error (0x404). Contact your IT administrator for assistance.
For detailed information about the session disconnect codes, see What do the PCoIP server log disconnect codes mean? (KB 1094).
You can choose to display:
  • Show All– This option shows all disconnect messages including Info, Warning, and Error messages.
  • Show Error and Warnings Only – This option hides info messages and displays only Error and Warning messages.
  • Show Error Only – This option hides Info and Warning messages and displays only Error messages.
  • Show None – Don’t show any disconnect messages.
Organization ID Enter an organization ID for the company (for example, 'mycompany.com'). This field accepts any UTF-8 character.
You only need to specify this parameter if the PCoIP Connection Manager requests it. The organization ID is used for certain types of PCoIP Broker Protocol authentication messages.
