Configuring User Interface¶
The User Interface tab of the On Screen Display (OSD) allows you to change the color palette of the OSD making the OSD appear less bright to accommodate low light environments. This setting can be locked or removed by the PCoIP Management Console.
Processor Reset
Changes to this setting requires a PCoIP Processor reset before the change takes effect.
Low Light Setting
The image below shows the difference in brightness when using the low light setting.
