Clearing the Management State¶
Setting | Default | AWI | OSD | Management Console |
Clear Management State (a button) |
:fa-minus: | :fa-check: | :fa-check: | :fa-check: |
From the AWI and OSD, you can clear the Tera2 PCoIP Zero Client's management state.
Clearing the management state removes the current endpoint manager information for the client. Once the client is managed by an endpoint manager, you must clear its management state before the client can accept a new endpoint manager.
You clear the management state from the AWI and OSD Management pages, shown next.
Discovery settings determine what displays on the AWI Management page
The information that displays on the AWI Management page depends on whether the client uses automatic or manual discovery.
OSD Management page
AWI Management page – automatic discovery mode
AWI Management page – manual discovery mode
To clear the management state:
- From the OSD or AWI, select Configuration > Management.
- From the OSD or AWI Management page, click Clear Management State so that the endpoint will accept a new endpoint manager.
- To save your updates, click OK from the OSD, or click Apply from the AWI.
