Testing Audio¶
Setting | Default | AWI | OSD | Management Console |
Start (a button) | :fa-minus: | :fa-check: | :fa-xmark: | :fa-xmark: |
Stop (a button) | :fa-minus: | :fa-check: | :fa-xmark: | :fa-xmark: |
From the AWI Audio page, as shown next, you can generate an audio test tone from the Tera2 PCoIP Zero Client.
AWI Audio Page
You can't perform audio tests during a PCoIP session
You can only start and stop an audio test from the Tera2 PCoIP Zero Client if the client isn't in a PCoIP session.
To generate an audio test tone:
- From the AWI, select Diagnostics>Audio.
- From the AWI Audio page, click Start to start the test tone, or click Stop to stop the test.
