Using the Packet Capture Tool¶
Setting | Default | AWI | OSD | Management Console |
Start (a button) | :fa-minus: | :fa-check: | :fa-xmark: | :fa-xmark: |
Download (a link) | :fa-minus: | :fa-check: | :fa-xmark: | :fa-xmark: |
The AWI Packet Capture page, as shown next, provides a diagnostic tool to capture network packets on the Tera2 PCoIP Zero Client. Using the packet capture tool may be requested by our support team.
PCoIP traffic isn't included in the Packet Capture
PCoIP traffic is not included in the packet capture. All other network traffic, is captured.
The following parameters display on the AWI Packet Capture page:
Parameters | Description |
Packet Capture Status | Displays the status of the packet capture tool. Values include: - Idle: Packet capture has not been initiated. - Running: Packet capture is in progress. - Stopped: Packet capture has been stopped. |
Bytes (Captured/Max) | Shows the number of captured bytes over the maximum number you can capture (in numeric and percentage format) along with the number of packets captured. |
Diagnostic Packet Capture | Click Start to start the capture and click Stop to stop the capture. |
Diagnostic Packet Capture | Click Download to save packet_capture.bin to the desired location on your computer. |
Idle Status
After performing a packet capture, the status displays as Idle if you reboot the Tera2 PCoIP Zero Client.
packet_capture.bin
contains network packets
Packets are captured into a binary file called packet_capture.bin
. A maximum of 20 MB of data can be captured. If you don't stop the capture,
it will automatically stop when it reaches the maximum.
To capture network packets to troubleshoot an issue:
- from the AWI, select Diagnostics > Packet Capture.
- From the AWI Packet Capture page, click Start to initiate the packet capture.
- Repeat the steps required to reproduce the issue.
Click Stop to stop the packet capture.
The
packet_capture.bin
file contains network packetsPackets are captured into a binary file called
packet_capture.bin
. A maximum of 20 MB of data can be captured. If you do not stop the capture, it will automatically stop when it reaches the maximum size. -
Click the Download link.
- Save
packet_capture.bin
to a location on your computer.
