PCoIP SNMP Agent Supported MIBs
A Management Information Base (MIB) is a list of variables that can be exchanged between an SNMP manager and agent. The MIB defines each variable and attributes about each variable.
The PCoIP SNMP agent supports the following standard MIBs as well as the TERADICI-PCOIP-MIB and TERADICI-PCOIPv2-MIB.
Supported MIBs
1.1.1 MIB-2 (RFC1213)
The MIB-2 MIB is the mandatory core SNMP MIB.
Interfaces Group
The Interfaces Group is one of the groups in the MIB-2 MIB. The Interfaces Group of a PCoIP device maintains statistics for two different interfaces (LOOPBACK and TERA_DSI). The LOOPBACK interface is self-explanatory. The TERA_DSI interface is the slow-path control interface. Care should be taken when using the Interfaces Group statistics. These statistics do not keep track of all packets processed by a PCoIP Zero Client or Remote Workstation Card. Statistics on the fast-path packets are not maintained in the interfaces group. Statistics on all packets processed by the PCoIP device, including the fast-path packets, are available in the EtherLike-MIB and RMON-MIB MIBs.
This MIB is supported in Teradici firmware revision 1.0 and all subsequent revisions.
1.1.2 EtherLike-MIB (RFC3635)
The EtherLike-MIB consists of extensions to MIB-2 dealing specifically with Ethernet and Ethernet-like interfaces. RFC3635 updates some definitions and deprecates others in response to management experience with RFC2665, it also incorporates support for 10 Gb/s interfaces.
1.1.3 RMON-MIB (RFC2819)
The RMON-MIB consists of optional extensions to MIB-2 which are used for statistics gathering and remote network monitoring and management. The only MIB object within the RMON-MIB currently supported is the Ethernet Statistics Group.
1.1.4 TERADICI-PCOIP-MIB
The PCoIP SNMP agent supports reporting the management information defined in a PCoIP defined MIB. The first generation TERADICI-PCOIP-MIB is described in this section and can be downloaded here.
The TERADICI-PCOIP-MIB maintains PCoIP and imaging statistics in two different groups or tables. Table 1-1 describes the PCoIP statistics and Table 1-2 describes the imaging statistics. PCoIP sessions capable of supporting multiple displays maintain and report imaging statistics for each display.
Table 1-1: PCoIP Statistics
Parameter Description
pcoipStatisticsSessionNumber PCoIP session number used to link PCoIP statistics to imaging statistics
pcoipStatisticsPcoipPacketsTransmitted PCoIP packets transmitted during the current or most recent session
pcoipStatisticsPcoipBytesTransmitted PCoIP bytes transmitted during the current or most recent session
pcoipStatisticsPcoipPacketsReceived PCoIP packets received during the current or most recent session
pcoipStatisticsPcoipBytesReceived PCoIP bytes received during the current or most recent session
pcoipStatisticsPcoipLostPackets PCoIP packets detected lost during the current or most recent session
pcoipStatisticsPcoipLatency Approximate total round-trip PCoIP system (e.g. Remote Workstation Card to Zero Client and back to Remote Workstation Card) and network latency in milliseconds (± 1ms) during the current or most recent session.
Table 1-2: Imaging Statistics
imagingStatisticsSessionNumber PCoIP session number used to link imaging statistics to PCoIP statistics
imagingStatisticsSessionActive Indication of whether the imaging session is active or inactive
imagingStatisticsDisplayActive Indication of whether the display is active or inactive
imagingStatisticsDisplayWidth Width of display in pixels
imagingStatisticsDisplayHeight Height of display in pixels
imagingStatisticsDisplayRefreshRate Display refresh rate in Hz (opposed to the PCoIP frame update rate calculated using imagingStatisticsFrameCount)
imagingStatisticsFrameCount Encoded frame count per display
  • This statistic is only maintained on Remote Workstation Card devices. Zero Clients set this statistic equal to zero.
  • This statistic can be used to calculate the frame rate of each display (frames per second). To do this, sample the counter twice and divide the difference between the two samples by the number of seconds that elapsed between gathering the two samples.
1.1.5 TERADICI-PCOIPv2-MIB
Superseding the TERADICI-PCOIP-MIB listed above, the PCoIP SNMP agent additionally supports a newer MIB version. TERADICI-PCOIPv2-MIB can be downloaded here). Although the previous MIB is still supported, Teradici recommends the use of the PCOIPv2-MIB exclusively for device information and statistics.
The TERADICI-PCOIPv2-MIB maintains a number of statistics in addition to device details. The general grouping of statistics are:
Device information is grouped into the following categories:
This MIB is supported in Teradici firmware revision 4.0.0 and all subsequent revisions.
Table 1-3: PCoIP Session General Statistics
pcoipGenStatsSessionNumber PCoIP session number used to link statistics to session. The session number is currently always set to the default value of 1.
pcoipGenStatsPacketsSent Total number of packets that have been transmitted since the PCoIP session started.
pcoipGenStatsBytesSent Total number of bytes that have been transmitted since the PCoIP session started.
pcoipGenStatsPacketsReceived Total number of packets that have been received since the PCoIP session started.
pcoipGenStatsBytesReceived Total number of bytes that have been received since the PCoIP session started.
pcoipGenStatsTxPacketsLost Total number of transmit packets that have been lost since the PCoIP session started.
pcoipGenStatsSessionDuration An incrementing number that represents the total number of seconds the PCoIP session has been open.
Table 1-4: PCoIP Session Network Statistics
pcoipNetStatsSessionNumber PCoIP session number used to link statistics to session. The session number is currently always set to the default value of 1.
pcoipNetStatsRoundTripLatencyMs Round trip latency in milliseconds between server and client.
pcoipNetStatsRXBWkbitPersec Average number of kilobits per second that have been received since the PCoIP session started.
pcoipNetStatsRXBWPeakkbitPersec Peak bandwidth for incoming PCoIP packets within a one second sampling period.
pcoipNetStatsRXPacketLossPercent Percentage of received packets lost during a one second sampling period.
pcoipNetStatsTXBWkbitPersec Average number of kilobits per second that have been transmitted since the PCoIP session started.
pcoipNetStatsTXBWActiveLimitkbitPersec The current estimate of the available network bandwidth, updated every second.
pcoipNetStatsTXBWLimitkbitPersec Transmit bandwidth limit for outgoing packets.
pcoipNetStatsTXPacketLossPercent Percentage of transmitted packets lost during the one second sampling period.
Table 1-5: PCoIP Session Audio Statistics
pcoipAudioStatsSessionNumber PCoIP session number used to link statistics to session. The session number is currently always set to the default value of 1.
pcoipAudioStatsBytesReceived Total number of audio bytes that have been received since the PCoIP session started.
pcoipAudioStatsBytesSent Total number of audio bytes that have been sent since the PCoIP session started.
pcoipAudioStatsRXBWkbitPersec Per second average of audio data received. Reset after each read.
pcoipAudioStatsTXBWkbitPersec Per second average of audio data sent. Reset after each read.
pcoipAudioStatsTXBWLimitkbitPersec Transmit bandwidth limit for outgoing audio packets.
Table 1-6: PCoIP Session Imaging Statistics
pcoipImagingStatsSessionNumber PCoIP session number used to link statistics to session. The session number is currently always set to the default value of 1.
pcoipImagingStatsBytesReceived Total number of imaging bytes that have been received since the PCoIP session started.
pcoipImagingStatsBytesSent Total number of imaging bytes that have been sent since the PCoIP session started.
pcoipImagingStatsRXBWkbitPersec Per second average of kbits of imaging data received. Reset after each read.
pcoipImagingStatsTXBWkbitPersec Per second average of kbits of imaging data sent. Reset after each read.
pcoipImagingStatsEncodedFramesPersec The number of imaging frames which were encoded over a one second sampling period.
pcoipImagingStatsActiveMinimumQuality The lowest encoded quality in the most recent 1 second period.
pcoipImagingStatsDecoderCapabilitykbitPersec The current estimate of the decoder processing capability. This parameter should be expected to remain virtually constant on a zero client. Decoder capability will change on a View client depending on CPU loading.
pcoipImagingStatsPipelineProcRate The current pipeline processing rate in megapixels per second.
Table 1-7: PCoIP Session USB Statistics
pcoipUSBStatsSessionNumber PCoIP session number used to link statistics to session. The session number is currently always set to the default value of 1.
pcoipUSBStatsBytesReceived Total number of USB bytes that have been received since the PCoIP session started.
pcoipUSBStatsBytesSent Total number of USB bytes that have been sent since the PCoIP session started.
pcoipUSBStatsRXBWkbitPersec Per second average of kbits of USB data received. Reset after each read.
pcoipUSBStatsTXBWkbitPersec Per second average of kbits of USB data sent. Reset after each read
Table 1-8: PCoIP General Device Information
pcoipGenDeviceSessionNumber PCoIP session number used to link attached displays to statistics. The session number is currently always set to the default value of 1.
pcoipGenDeviceName String containing the PCoIP device name.
pcoipGenDeviceDescription String describing the processor.
pcoipGenDeviceGenericTag String describing device generic tag.
pcoipGenDevicePartNumber String describing the part number of the device.
pcoipGenDeviceSerialNumber String describing device serial number.
pcoipGenDeviceHardwareVersion String describing the PCoIP processor version.
pcoipGenDeviceFirmwareVersion String describing the currently running firmware revision.
pcoipGenDeviceUniqueID String describing the device unique identifier.
pcoipGenDeviceMAC String describing the device MAC address.
pcoipGenDeviceUptime Integer containing the number of seconds since boot.
Table 1-9: PCoIP Imaging Device Information
pcoipImagingDevicesIndex The auxiliary variable used for identifying instances of the columnar objects in the devices table.
pcoipImagingDevicesSessionNumber PCoIP session number used to link imaging devices to statistics. The session number is currently always set to the default value of 1.
pcoipImagingDevicesDisplayWidth Display width in pixels.
pcoipImagingDevicesDisplayHeight Display height in lines.
pcoipImagingDevicesDisplayRefreshRate Display refresh rate in Hz
pcoipImagingDevicesDisplayChangeRate Display input change rate in Hz over a one second sample. Input rate refers to the frame rate at which a video source is changing.
pcoipImagingDevicesDisplayProcessRate Display process frame rate in Hz over a one second sample. This parameter describes the frame rate that a PCoIP processor is actually processing and will always be equal to or less than the input change rate.
pcoipImagingDevicesLimitReason String describing the reason for limiting the frame rate of this display, if applicable.
pcoipImagingDevicesModel String describing the display model name.
pcoipImagingDevicesStatus String describing the display device status.
pcoipImagingDevicesMode String describing the display mode.
pcoipImagingDevicesSerial String describing the display serial number.
pcoipImagingDevicesVID String describing the display vendor ID.
pcoipImagingDevicesPID String describing the display product ID.
pcoipImagingDevicesDate String describing the display date of manufacture.
Table 1-10: PCoIP USB Device Information
pcoipUSBDevicesIndex The auxiliary variable used for identifying instances of the columnar objects in the devices table.
pcoipUSBDevicesSessionNumber PCoIP session number used to link USB devices to statistics. The session number is currently always set to the default value of 1.
pcoipUSBDevicesPort USB device port: OHCI or EHCI.
pcoipUSBDevicesModel String describing the model name of the connected device.
pcoipUSBDevicesStatus String describing the USB device status. This status string contains the connection state of the device, and will also show if a device has been blocked due to authorization restrictions.
pcoipUSBDevicesDeviceClass String describing the USB device class.
pcoipUSBDevicesSubClass String describing the USB device sub class.
pcoipUSBDevicesProtocol String describing the USB protocol used.
pcoipUSBDevicesSerial String describing the USB device serial number.
pcoipUSBDevicesVID String describing the USB device vendor ID.
pcoipUSBDevicesPID String describing the USB device product ID.
1.2 SNMP Version Support
The PCoIP SNMP agent supports SNMPv1, SNMPv2c and SNMPv3. SNMPv1 and SNMPv2c was available in Teradici firmware release 1.0 and all subsequent releases up to an including firmware 20.07. SNMPv3 is available in PCoIP firmware 20.07, and is the only configurable option in firmware 20.10 or newer.
1.2.1 Using SNMPv1
Table 1-11 defines the parameter settings when using SNMPv1 to interact with the PCoIP SNMP agent.
Table 1-11: SNMPv1 Parameters
Device Address End-point IP address (Remote Workstation Card or Zero Client)
Port 161
1.2.2 Using SNMPv2c
Table 1-12 defines the parameter settings when using SNMPv2c to interact with the PCoIP SNMP agent.
Table 1-12: SNMPv2c Parameters
Port 161
Read Community Name public
1.2.3 Using SNMPv3
Table 1-13 defines the parameter settings when using SNMPv3 to interact with the PCoIP SNMP agent.
Table 1-13: SNMPv3 Parameters
Port 161
SNMPv3 Auth Password enter strong password
SNMPv3 Priv Password enter strong password
Zero Client specific details
For PCoIP endpoint specific values, see the PCoIP Zero Client or Remote Workstation Card administrators guide for complete details.
1.3 SNMP Traps
SNMP traps are asynchronous messages sent by an SNMP agent to an SNMP manager when certain conditions occur. The PCoIP SNMP agent supports generating the following SNMP trap.
  • IF-MIB cold start
Other SNMP traps are enabled and disabled using a profile with the PCoIP Management Console and are disabled by default. For details about using a profile with PCoIP Management Console, please refer to Managing Profiles in the PCoIP Management Console Administrators Guide.
To enable traps, you must configure the following Network configuration parameters:
PCoIP Firmware Version
SNMP version 3 traps are only available when using PCoIP firmware 20.07 or newer. SNMPv1 and SNMPv2c are available up to and including firmware 20.07.
  • SNMP NMS Address: IP address of the SNMP management system the SNMP agent will send the trap to
  • Enable SNMP Cold Start Trap: boolean variable that enables cold start traps
  • Enable SNMP V1 Traps: boolean variable that enables v1 traps
  • Enable SNMP V2c Traps: boolean variable that enables v2c traps
  • Enable SNMP V3 Traps: boolean variable that enables SNMP version 3 traps
To enable or disable the generation of SNMP traps, the endpoints must be reset after modifying these parameters.
1.4 Known Issues
  • Two counters in PCoIP Zero Clients and Remote Workstation Cards do not function properly. They report random values for the following MIB counters. These counters should be ignored when analyzing the data reported by a PCoIP Zero Client or Remote Workstation Cards.
    • etherStatsPkts128to255Octets.2
    • etherStatsPkts1024to1518Octets.2
  • The statistic ifSpeed.2 should return an estimate of the interface's current bandwidth in bits per second. The PCoIP SNMP agent always returns the value 10Mbps.
  • The PCoIP SNMP agent supports reading but does not support modifying variables with read-write access.
