Client SDK for Linux
Developers' Guide
This release is in Beta. Beta software is not fully supported, and may be incomplete or unstable. It is not intended for use in production systems. We welcome your feedback on this release! Send feedback to anyware-beta-feedback@hp.com.
Building the SDK for Linux
This section includes instructions for building a custom client application by utilizing the SDK.
- As a reference, follow the CMakeLists.txt of the
broker_client_example
to understand the build steps using the Cmake tool, which is located at/usr/lib/x86_64-linux-gnu/pcoip-client/examples/broker_client_example/CMakeLists.txt
. - Run the CMake configure and verify that it configures without any errors.
- Run
make
to build the application. - The
find_package()
command of CMake automatically finds the libraries installed by the SDK.
Updating SDK Components
Updating the SDK to a new version can be done by installing a new version of the SDK. There is no special upgrade path.
Last updated: Thursday, June 12, 2025
