Linking the SDK for macOS
This section includes instructions for linking the SDK libraries with your custom client application:
Open a Terminal window and change directory to the root of the mounted SDK disk image.
Copy the SDK files to desired location for SDK development, refered to as
<sdk_location>
below.CMake modules location
The CMake modules for finding the libraries within the package are located inside the SDK framework /
<sdk_location>
/PCoIPSoftClientSDK/Resources/CMake. The required libraries are namespaced by PCoIPSoftClientSDK. -
To use the core APIs use the following commands on your applications CMake file for linking your application to the libraries that are needed from the SDK.
list(APPEND_CMAKE_PREFIX_PATH " /<sdk_location>/PCoIPSoftClientSDK/Resources/CMake") find_package(PCoIPSoftClientSDK REQUIRED)
Use the following command to link your application to the core library using the
CMake
command, replacing<your_application>
with your own application name:target_link_libraries(<your_application> PRIVATE PCoIPSoftClientSDK::pcoip_core )
You can link to any other required libraries similarly by appending it to the above command.
