Client SDK for macOS Developers' Guide
This release is in End of Availability. The release is no longer available from Teradici. You must upgrade to a supported release.
Limits on Customization
The macOS has elements which are part of the operating system user interface and cannot be modified programmatically, as described in the following sections.
macOS Limitations
The following run-time limitations are enforced by macOS on the application menu (beside the menu apple icon menu):
  • The menu title cannot be altered. The menu title will be Anyware Client.
  • The Hide... menu item label cannot be altered. The menu item will be Hide Anyware Client.
  • The Quit... menu item label cannot be altered. The menu item will be Quit Anyware Client.
The session client will also appear as Anyware Client in the Force Quit dialog.
Bypassing run-time Configuration Limitations
The limitations described here are enforced at run time. It is possible to bypass these restrictions by editing the plist file. Modifying this file will invalidate the HP signature.
macOS 10.12 Application Support
In order to enable branding packages in macOS 10.12, you must remove the quarantine bit from all files in the session SDK package. If you To remove the quarantine bit, open a terminal and type:
xattr -dr com.apple.quarantine <PATH_TO_SDK_FOLDER>
Last updated: Wednesday, October 30, 2024
