Client SDK for macOS Developers' Guide
This release is in End of Availability. The release is no longer available from Teradici. You must upgrade to a supported release.
About PCoIP Sessions
Establishing a PCoIP session involves a number of key components, including system actors, PCoIP session phases, and connection brokers as discussed next.
System Actors
There are at least three components that work together to create a PCoIP session:
  • Anyware client: The hardware or software device, local to the user, which requests and drives the PCoIP session by negotiating with PCoIP brokers and Anyware agents.
  • PCoIP Broker: Brokers maintain lists of active users, their authentication information, and the host machines they can connect to. Except for systems using direct connections, all PCoIP sessions are negotiated via third-party brokers.
  • Anyware agent: The extension installed on the host machine. The Anyware agent is the single point of access for Anyware clients, and handles all video, audio, and USB exchanges between the client and desktop.
Terminology: Hosts and Desktops
Host refers to a Windows, or Linux machine, either virual or physical, which has a Anyware agent installed and can serve a remote desktop to a Anyware Client. Desktop refers to an entity which is delivered to the client as a remote workload. This is typically a full Windows or Linux desktop, but it can also be configured to present a single application.
The following diagrams show the actors outlined above in a brokered and direct connection:
Direct Connection
Brokered Connection
Last updated: Wednesday, October 30, 2024
