Client SDK for macOS Developers' Guide
This release is in End of Availability. The release is no longer available from Teradici. You must upgrade to a supported release.
Connecting to a USB Device
Remote hosts using the Anyware Standard Agent or the Anyware Graphics Agent can use USB devices that are attached to the client. When you connect a local USB device to your remote host it will be disabled on the client machine.
USB device connections do not persist across multiple PCoIP sessions. You must connect your USB device each time you connect.
Anyware Agent needs to be configured to enable USB redirection
The USB menu will only show up if the Anyware Agent has been configured to enable USB redirection and a USB device has been detected by the Anyware Client.
One-time Anyware Client login
The first time you connect after a Mac installation, you must enter a Mac administrator user name and password. You only need to do this when you install a new client.
To connect to a USB device:
  1. Attach the USB device you wish to connect.
  2. Select Connection > USB Devices from the Anyware Software Client menu.
    A list of USB devices connected to your client machine appears. Integrated USB devices, such as built-in cameras on laptops, will appear in this list along with devices you have plugged in yourself.
    Some devices will identify themselves only as USB Device.
  3. Click Connect beside the USB device you wish to use.
Connecting to Human Interface Devices
Most Human Interface Devices (HIDs), such as keyboards and mice, are automatically handled by the Anyware Software Client and do not appear on in this list even if they use a USB connection.
If you need to connect a Human Interface Device that cannot be locally processed, like a 3D mouse or a Wacom tablet, enable the Show Human Interface Devices checkbox to reveal the device in the USB device list and click its Connect button.
You may also have to complete additional configuration steps or install drivers on the host machine.
To disconnect a USB device:
  1. Select Connection > USB Devices from the Anyware Software Client menu.
  2. Click Disconnect beside the USB device you wish to disconnect.
Last updated: Wednesday, October 30, 2024
